right, my prob bad explanation of dressing cable,
1 NEVER clip in front of yourself,
2 RH people on a LH draw take the cable in your left hand and pull it away from the wall, and then push it along with the OS edge of your right hand until you get past the next clipping point,
3 LH back to point and hold clip in place, RH, 2 bangs and its home,
4 step 2
am I the only person this is making sense to?
---------- Post Auto-Merged at 00:08 ---------- Previous post was made at 00:06 ----------
Right, having had an Espresso, try this.Put drum flat on floor
stand slightly over and behind the drum take loose end of wire in left hand
slightly ease cable off/over flange of drum and catch with right hand
flick cable up and catch with left hand whilst still holding the bit you started with
then repeat with right hand
keep doing this til you have a few metres off. In effect you have taken a lump of cable off the drum BUT it is still coiled up and in a coil slightly larger than the orignal drum size...with me so far??
Now 'walk out' the cable laying it out on the floor and it 'should' keep itself flat
then clip it
I am not reading that back to myself as my brain will explode........... :coat
that has got to be one off the most amateur bits of advice ever,
KERCHING, Im disappointed in you,!!!
SERIOUSLY
talk about DIY Drunken BOB and his Brother.!!!!
---------- Post Auto-Merged at 00:09 ---------- Previous post was made at 00:08 ----------
Mrs Streetwalker, are you R or L handed?
