- Nov 28, 2009
- 14,729
- 903
Called to look at several jobs in one house today.
One is the electric heating system. It's an electric boiler combined with a heat exchange ventilation system and hot water tank. The users manual for it is here http://www.nibeonline.com/pdf/411483-1.pdf
The problem is the 40A MCB feeding it is tripping every other day. It used to be every few weeks, but it's got progressively worse.
I tried measuring the power it was drawing buy my b****y clamp meter seems to have packed up and was telling me just 2 amps.
I could really do with the installers manual for this.
All I have been able to determine so far is you can adjust the heat input between 7.5KW and 13KW If it's set to 13KW then it's no wonder a 40A MCB is tripping. So I want to find out how you adjust that. I suspect it's wire links or jumpers inside the unit.
Before my next visit I'll check out / repair / replace my clamp meter so I can actually measure what power it's drawing.
This one is yet another example of what to me seems unnecessarily expensive heating. Why would anyone choose to install an electric boiler like this, to drive wet under floor heating, and NOT even put the property on E7 or E10 tariff ?
As I keep saying if you are going to heat your home entirely by electricity, I would have though electric heating mats in this case to give electric under floor heating would be better.
