Manator
©Honorary Essex Boy™
Applying codes on any inspection is always going to provide controversy. A few years ago I did an inspection when we all called them PIr's I found a damaged light switch in the basement. I down graded my code because the only user who had access was the only person who had the key, was aware of the danger and took precautions when he used the switch. There were no exposed live parts but any deterioration would prove to be dangerous.
I have also just carried out an inspection on a factory that has its own maintenance electrician, so you would assume that any codes I gave would reflect this? Not so, most of what he has done is a disgrace and I have pulled his work and repairs up to such an extent that I told him not to install anything in future. He could not see the problem with a double socket outlet being wired from a 63amp 3ph isolator, as he was only using one of the phases he thought it was OK.
