D Dambo Senior Member Joined Oct 7, 2009 Messages 473 Reaction score 0 Sep 7, 2010 #1 Hi guys. It's been a while since i''ve been on here, it's good to be back Just wanting a bit of advice as i'm having another of those blonde moments :Blushing When wiring an outside PIR Light is 3C+E used or it just 2C+E?
B Brian 157 Senior Member Joined Jan 26, 2009 Messages 366 Reaction score 0 Sep 7, 2010 #2 If integral PIR should only need T&E, if separate either T&E in & T&E out or 3C&E to give switch return.
D Dambo Senior Member Joined Oct 7, 2009 Messages 473 Reaction score 0 Sep 7, 2010 #3 If integral PIR should only need T&E, if separate either T&E in & T&E out or 3C&E to give switch return. Click to expand... How would the 3C+E be wired up in that case?
Badger Gold Member Supporting Member Joined Feb 24, 2008 Messages 6,171 Reaction score 115 Location Staffordshire Sep 7, 2010 #4 that would be used with an ovverride switch making the light being able to be used when ever you want
