Manator
©Honorary Essex Boy™
try sending it to me at manator @electricianforum.co.uk
Remove the space between manator and @
Send as a PDF
Send as a PDF
I thought you were going to say why do you have a diagram for parallel PIR's to same load? Just common all the Sw Lives together then to the load surely.why do you have a diagram as PDF? surely it would be better as jpeg or similar
?ye but i duno why i always like doing the over ride that way. save a bit of cable to
your way could use more cable depending where switch, light & PIR's are located...ye but i duno why i always like doing the over ride that way. save a bit of cable to
Do you really think he would forget to wire a neutral to the PIR's?!erm what about the missing neutral in the pir or am i clutching at straws again :coat
Only if you mentioned its missing at the light also ;erm what about the missing neutral in the pir or am i clutching at straws again :coat
But his drawing DOES show neutral to the light.It doesn't show any CPC though. :coatOnly if you mentioned its missing at the light also ;
Quite right, i need to go and scrub the eyeballs. Been drilling downlight holes all afternoon.But his drawing DOES show neutral to the light.
