PIR Light Connections
babulmiah
Oct 26, 2022
21
bedfordshire
Would someone be able to help me with the wires in the picture, which would go to brown, blue and earth wire?
Trying to connect pir light which I disconnected many years ago.
It looks like (and this is at your own risk) Brown - Black.
Blue - White.
Earth - Green & Yellow.
The blue wire looks like a return to possibly allow a second lamp to be added, so I'd put it in a separate connector block.
This is only my opinion from tracing where the cables go in the fitting on the photograph.
It's a made in China fitting using hot and cold wiring references, but that blue is the odd one.
If in doubt get an electrician in who can test the unit.
Blue - White.
Agreed and further, I think, the blue and white wires were paired in the manufacturers original connector block
