I've had this exact problem at least twice now and it's always been the same thing![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
slow down,Initial thoughs..Firstly I would establish exactly which lights light up with all switch combinations..
and if they are at full brightness..
:|ray
Sorry dad!right you last three,I think that you shouldnt be trying to solve this,
maybe trying to hint at how you would do things,
Deke, there is NO lead sheath cable in this house, I dunno if you have seen the new PVC stuff yet!![]()
alpha, loft light is harmonised colours, now what are the issues with that as regards the original install?
---------- Post Auto-Merged at 23:25 ---------- Previous post was made at 23:24 ----------
slow down,
we dont want the answer, we want the reasoning.
A hole in one there Deke, absolute Genius!!!!!!!:worship :SaluteWhat is the significence of the smoke detectors ? Or has someone forgot to solder the lead sheaths together with the blowlamp,sticks of solder and ,being lead, the tallow as a flux, I see it all now , the neutral from the loft is going down the lead sheath to that untracable Imm.Htr circuit and is in series with the unused element, hence no other lamp dimmed, from there down an unconnected bit of copper pipe which is touching an old steel conduit switch drop which has a screw through it , connecting it to the interlink wire of the Smoke detector circuit, through the electronics , down the neutral , which is connected to the switch wire of the hall light which has a green /yellow as a return down a copper sink waste pipe which only makes a connection when water runs through it.
My case rests.![]()
Elementary my dear Watson , I also deduct that the original sparks was from Eastern Europe, a swarthy man with one leg shorter than the other ,a glass eye and a propensity to pick his nose , break wind frequently and smoked Woodbines . Probably not very popular.
and you have never even met me!!!!!!Elementary my dear Watson , I also deduct that the original sparks was from Eastern Europe, a swarthy man with one leg shorter than the other ,a glass eye and a propensity to pick his nose , break wind frequently and smoked Woodbines . Probably not very popular.---------- Post Auto-Merged at 00:21 ---------- Previous post was made at 00:20 ----------
That's not fair Steps.....I would NEVER call you eastern europeanand you have never even met me!!!!!!
Well the answer to Life The Universe and Everything is #42..#42 almost gives it to you,almost.
but tell me how.
