- Dec 2, 2009
- 350
- 0
Family member had a lot of work done some months back, they ended up kickeing the builder out...
Now, the newly installed boiler is having problems and I'm reluctantly getting draggedd into the whole mess.
Upstairs stat dosent seem to turn the heating off, downstairs one does. I've never had anything to do with heating systems but I'm pretty sure this is a shoddy jobby...
Sheath ripped open way outside enclosure...
Twisted my head round to see a lovely job of box butchering... Cables gripped/nipped by box lid, all fell out when lid removed.
Looks like a second load from the spur is stuffed in the top of the spur - not sure if there is actually a box in the plasterboared or just a hole cut in board, not had time to look.
and yes that is a cable covered with a bit of conduit lid cable clipped into position.
Also...
Swapped two stats over - not expecting a cure but was asked to do it,
Noticed 3 core flex used on both stats, sheath outside of enclosure with cores nipped into position by surface mounted stat
Connections:
Green Yellow-Common
Brown - N/O
Blue - cut off!
Motorised valve behind storage vessel - god knows how thats servicible
Also...
Connections:
Green Yellow-Common
Brown - N/O
Blue - cut off!
