Smoke/ Heat/ Co Alarms
Revved Up Sparky
Aug 3, 2009
752
North Wales
A friend (who is a landlord) has asked me to install mains powered smoke/ heat/ co detectors in one of his properties, a first floor flat.
Admittedly I have'nt had time to do any research yet but I would like to pick some brains if that's OK.
3 Questions
1. In an L shaped kitchen/ living room, kitchen part about 10ftx10ft, living room part about 15ftx10ft, do I need to fit a smoke detector in the living room part ? my concern is that cooking will set it off - I am putting a heat detector in the kitchen part.
2. There is no oil or gas central heating boiler - but there is an open fire in the living room area, do I need to fit a CO detector ?
3. The main reason for my friend wanting this work done - the flat is non smoking and his tenant is smoking - he wants smoke detectors that will sound when a cigarette is lit. Are there smoke alarms that are this sensitive ? do you know what make / model ?
I will be putting smoke detectors in the bedrooms as the hall between the bedrooms is only a metre square and a loft hatch dominates the ceiling- no room.
Any input appreciated, thanks
From 1st December it's the law here that rental properties have hard wired alarms. That's just about all I am doing now.
I would say heat and CO in the living room / kitchen and a smoke in each bedroom should cover it.
I hope it's a top floor flat with a loft otherwise I don't envy you the task of wiring those with no access to the floor above.
Thanks Dave, yes it's a top floor flat so there is an attic above.
We have been fitting CO's in vicinity of gas boilers for a while now, appears as standard spec on HA's housing. I always thought that the CO's are required wherever a fuel is burnt?
I've also seen that.....
However.... my fathers uncle and aunt were killed by carbon monoxide poisoning in a caravan, 60 years ago, so IMHO it applies to gas as well..
although, modern boilers are room sealed so any co2 will be vented outside through the flue....
if,
they are sealed properly and not faulty.
what about that idiot plumber/gasman that murdered his girlfriend and her daughter by running a genny inside a boat and modifying the exhaust?  :shakehead
smoke alarms wont detect cigarette smoke. You can get cigarette detectors, but they can be disabled if battery operated and can be activated by toasters etc in the kitchen (and open fire) if hardwired and can be expensive.
The heat detector in the kitchen may be activated by the open fire.
The smoke detector in the living room may be activated by toasters etc. and by the open fire
Tricky one
So the landlord doesn't want a smoker, but allows an open fire?
Tricky one
you sure about that?
we ran out of canned smoke testing a residential home once, and as the only smoker on the crew that day,
I almost killed my yearly quota in one day testing the remainder of the heads,
ok, it wasnt an instant alarm, but, it did set them off,
I stand corrected, I can imagine it would work in close proximity, up a ladder :)
but it wouldn't deter a determined smoker. I wouldn't have a dedicated circuit for the alarms either, if they are going to smoke and switch it off at the CU, they can do it in the dark.
This is what I thought....but i am sure I. Have seen the words "solid fuel"
Part k I think it is, CO detector should be within 2m horizontally of any solid fuel burning appliances, or words to that effect.
thinking about it though,
would normal domestic smoke detectors be different?
and would optical or ionisation react in different ways too?
mmmmmmm   :C
Not wishing to be pedantic but CO2 is what makes fizzy drinks fizzy.
Carbon monoxide is CO it is the bi-product of improper combustion.
Carbon monoxide can be produced by either solid or gas fuel improperly burning.
There is such a thing as a cigarette smoke detector. When it detects fag smoke it speaks.
Click here
There is a video of the original see
https://www.youtube.com/embed/_WruQRcwB5o?feature=oembed
