Manator
©Honorary Essex Boy™
The codes are subject to the examiners assessment at the time of inspection. The two code two,s that I gave was for a light switch at the bottom of a cellar staircase. The class II switch was broken and no earth was taken to the switch, I gave a code 2 for each, it could very easily have been a code 1, however the cellar door was locked and the only person with access was aware of the danger, therefore my risk assessment in this instance was that the risk posed no immediate danger, and as such a code 2 could only be given. This is by following the guidance provided, however it did not prevent me from giving a stern warning that it should be a priority to be replaced. The code 2 for no earth at a class II switch was given because of the fault with the broken cover, otherwise it would have been a code 4.
