Where abouts in the country did you have dinner with him?
I was going for ....a Restaurant, could have been Maccy D's. But I do know snakey has some standardsA dining room perhaps
It was only a Brewers Fayre, but not bad.I was going for ....a Restaurant, could have been Maccy D's. But I do know snakey has some standards
That I would say is a very astute observation BD!isn't he stroma's version of Tony Cable? :lol:
He probably wouldn't like that...
I would suggest you read it first.Some bloke called "John Peckham" says...
The use of bonding clamps as an alternative to glands.BS951 bonding clamps are designed for clamping on to solid pipes. The force required to make a reliable tight joint on to a SWA cable would effectively deform the cable and may loosen over time due the continued deformation of the cable. The insertion of a piece of copper water pipe under the armour to prevent deformation is bad practice as the SWA armour is galvanised steel which may react with the dissimilar metal copper insert. The use of Jubilee clips to terminate the armour is an absolute bodge (see Regulation 134.1.1)
john..
Astute indeed Mr sidewinder.That I would say is a very astute observation BD!
There will be those who get that and those who don't.
Explain this termination kit?I did, it says; "proper materials shall be used in the erection of the electrical installation"
Jubilee clips were not designed as electrical equipment, they are hose clips... Mr Peckham obviously shares this opinion or he would not have made his comment above.
john..
Yes....but that is relevant to,the type of termination we use in THIS country being applied to,the type of cable we use in THIS country!
