That "summation" supply Job
Steps,
FWIW I won't use a neon either, seen to many catastrophic failures of resistors!
Andy,
I think my KEW does too, just noticed it the other day as I "normally" put the probe onto the N/E 1st.
Will check next time I get it out of the box.
KEW1710 IIRC, the one with the V readout as well as the LEDS.
Steps,
Andy,
but it wont on a broken neutral.will it.?
yes.
as soon as the probe touches somthing live (with other probe connected to nothing) it will give a warning.
connect other end to neutral, and it will still give a voltage warning, but wont display a voltage (needs another reference for that part to work)
yes.
Steps,
I'm not! going out to the van now, iit's cold & wet in Swansea!
I have to potter tomorrow tidy the van empty some stuff load up and move a few things around I'll have a play with mine and come back on this.
I suspect that the electronics use the fact that you are holding it, i.e. act the same as a neon! Thus you agan become part of the cct.
With clever trickery you can trigger the neons from almost nano amps of current flow.
Steps,
Steps,I'm not! going out to the van now, iit's cold & wet in Swansea!
Im just being pedantic now arent I.?
Steps,FWIW I won't use a neon either, seen to many catastrophic failures of resistors!
But it's NOT just a resistor between you and the live wire, it's a resistor AND a neon lamp.
Resistors normally fail open circuit, and I've yet to see a neon tube fail anything other than open circuit.
My own neon will glow dimly on a live wire even if you are NOT touching the metal end cap, thus showing how little current is actually needed to light a neon. So in that respect no different to a volt stick or any other "one probe" voltage indicator.
I like the security of using a neon screwdriver for terminal screws. NOT because I am using it as my primary means of "test for dead" but as an extra sanity check in case despite my testing I have overlooked something and accidentally left something live. That to me is it's main function.
OK, so I can stick a piece of wood on a live wire and it will show me a result.?
good,.if the wood is able to conduct then it probably would. if i remember tomorrow, i may even try it
cos I always thought an electric current required a path to earth to be evident.evidently not
perhaps someone can tell me this is a massive fallicy in ohms law .
not sure exactly how it works, but megger mark may be able to
Steps,
NO, yes, no, yes oh I don't know!
Prodave,
Carbon resistors yes the predominant failure mode is to fail o/c.
As is the same with a neon.
HOWEVER, do you want to take the risk?
Remember very often when GLS lamps fail the ionisation in the envelope allows such a current to flow that it trips the mcb!
Steps,
Prodave,
But it's NOT just a resistor between you and the live wire, it's a resistor AND a neon lamp. Resistors normally fail open circuit, and I've yet to see a neon tube fail anything other than open circuit.
My own neon will glow dimly on a live wire even if you are NOT touching the metal end cap, thus showing how little current is actually needed to light a neon. so in that respect no different to a volt stick or any other "one probe" voltage indicator.
normally fails open circuit isnt good enough. what about the time when it fails closed and kills you.
Prodave,
Not quite the same as the non contact types though is it.
They are not in contact with the live conductor, they probably pick up the em field emitted.
