Sharpend
"It Just Is"
How about a Bosch 10.8v on a low torque setting? All I need to know is which number setting??
But what about if they are too tight and how would you know without loosening them. LolOK -to throw oil on the fire...............http://www.neweysonline.co.uk/neweys/pdf/WI00_Torque_Setting_Data_Technical.pdf
And, as far as the EICR comment goes - you wouldn`t loosen them, but if they were too loose, you could tighten them..............
No you could not tighten them as you would be in breach of statute law in doing this.OK -to throw oil on the fire...............http://www.neweysonline.co.uk/neweys/pdf/WI00_Torque_Setting_Data_Technical.pdf
It will be the sort of thing that if everyone has a set the price will fall. I'd have thought they could knock the above set out for ~Got offered one of these today.......Buy Wiha 10-Piece Torque Screwdriver Set, slimVario/slimTorque, VDE, Slotted/Phillips/Pozidriv - 36078
How much would you pay, seriously?
use the torque setting built into my wristWhat would you do if you torqued it to the required amount and felt it wasnt enough? ignore it and do it a bit more? or leave it and worry all night, but feel rest assured the manuf would come to you rescue if it went into meltdown?
Doesn't feel alot piece of **** to undo as well, certainly not enough that you'd feel comfortable leaving it at that (just had a non scientific test with my torque wrench)Thats a expensive chocolate teapot then! Anyone know what 1.7NM feels like? doesnt sound alot to me.
So in effect we'd be better off leaving it upto the installing electrician to judge the soundness of his connections rather than an arbitary number?, as for rotating machines, how about the factory maintence department inspecting for that and other faults from time to time (if they havn't all been contracted out!)You also need to realise that these torque settings are for devices connected in the fixed structure of the building.Thus not subjected to any external influences, vibration, which is an external influence will need to be considered if the termination is subjected tot his such as in or attached to a rotating machine otherwise subjected to vibration, and, that this may well have an affect on the required torque setting, as may the number and make up of he conductors present at the termination.
I think what he's saying is a CU is not designed to a set/known amount of forces - A machine in a factory is, as that is how its designed (fixed or moving)So in effect we'd be better off leaving it upto the installing electrician to judge the soundness of his connections rather than an arbitary number?, as for rotating machines, how about the factory maintence department inspecting for that and other faults from time to time (if they havn't all been contracted out!)
are you on the correct thread Manator? :CI think there are some of you who are thinking what the hell? Well, I am going to try to explain. What Sidewinder is aiming at is for our protection, you can if you wish ignore his advise, but if I where you I would listen and take note. To be honest the implications and comebacks are very remote, Sidewinder would agree with me here, however, I for one am glad Sidewinder brought this to my attention, at least now I know that I am expected to take full responsibility for the design and use of an adapted consumer unit.Take note, we are all to often taken for granted.
