Manator
©Honorary Essex Boy™
No
Good advice that - No matter how tight you get it first off, its always loose after you have moved it about a bit afterwards!. I also try and take out the hight twist in the strands of meter tails and form them into a more flat or square cross section than the circular they come in to allow maximum contact area with the box terminal...give it a try next time you connect some 25mm tails...tighten to what you think is correct, leave it a couple of minutes, give it a twiddle and see if you can get a couple more turns on it. The bigger the cables [solid strands NOT trirated stuff], the worse they are
Who's asked you for those then Manator?Just thought I would bump this thread.My reason is I have been asked to provide all torque settings and a copy of my torque drivers calibration certificate with all issued EIC's.
Good job I have a set or I would have been goosed.
To be read in the style of that irritating theatrical gob s h i t e John Sessions ' me Sir Me Sir.....134.1.1 Sir, thank you Sir as I said to Johhny Gielgud the other name dropping day:coat '.........It is actually a requirement under BS7671.Lets see if anyone knows why.
Are they asking for each individual setting? or just M3 = XNm, M10 = YNm ?Just thought I would bump this thread.My reason is I have been asked to provide all torque settings and a copy of my torque drivers calibration certificate with all issued EIC's.
I do,It is actually a requirement under BS7671.Lets see if anyone knows why.
