You're close to the answer that I was looking for, but I wanted to hear it from Steptoe - with his reasons for ranting on every time it's mentioned.The system you are looking to describe is actually PNB (Protective Neutral Bonding), although the rod isn't necessarily at the star-point.
Both PME and PNB are forms of CNE, and both can be used to supply TN-C-S.
BUT.......
PNB is used rarely - it's specialist.
You're not going to find it on a housing estate in Birmingham
It can, as you say, be implemented by someone with there own supply/transformer.
If it's from a public supply, it will normally only be used to supply one individual consumer - probably for safety with regards to losing the neutral.
So, when one of the lads on here refers to TN-C-S (PME), there's about a 99% chance that they are right, with regard to the system that they are describing, and about a 1 % chance that they are describing a TN-C-S (PNB) system in error.
So is there really any reason to rant on every time someone mentions the two together?? ; \
