Sharpend
"It Just Is"
Lads bit of advice if I may.
Have a large dom property which has been refurbed. It has UFH on ground floor conventional rads on top two floors plus hot water. The plumber has said that it needs two boilers as one is not sufficient.
So wiring two together, anything I should be aware of? Wire in parallel to operate both at any one time? My concerns were if valves were closed pumps running against the closed valves?
Haven't got details from plumber as to how he has done his part as yet. I'm guessing that the boilers have internal pumps but only a guess.
Suggestions please.
Suggestions please.
