I have the same problem, difficult to type, eat and think at times!had one eye on the telly, and haven't had a beer yet!
Yep, concur.Erm, yes. It's a multistranded cable, surely you've seen these, 4mm and over is multistranded, as are conduit wiring cables. The exact cable type is a concentric to the left, and a split concentric to the right.
yes lurch it looks that way but if you look at the 2nd pic you can see the pme link on the earth bar. the edge is just in shot so that outgoing earth is connected to the incoming pen conductor- so next door everything will be good! if you know what i mean!If it is a looped feed to next door exiting on the right cable and you did a test next door and marked it as TN-S, would you not realise there was something amiss when you got no reading on PEFC as the earth terminal on the head is connected to nothing (assuming next door has the same head wired in the same fashion as the one in the pic here)?
