comptonspark
- Jun 4, 2009
- 8
- 0
I'm looking at a domestic rewire where the ground floor is suspended on normal floor joists with approx 9 inches below the bottom of the joists and the earth or builders rubble. My question is regarding the running of cables below the floor.
Obviously running cables across the joists I can drill the joists and pull the cables through but that then leaves the cables that run with the joists unsupported, unless I pull up lots more floorboards and clip cables to side of joists. Is there a good way of running cables in this case, or is it just acceptable to run all the cables below the joists?. I would prefer a neater solution, that keeps the cables off the rubble, but don't want to totally destroy the floors to clip direct.
