wander leads
ISSWWW
Jun 29, 2009
699
I know there is a lot of talk of wander leads on the forum, i am going to put these into stock: question is will any one be interested in them?
Main benifit is it leaves both hands free, cable is a better grade and it reels better than the other models we keep, it will be competitively priced.
By the way if you can't see it has a belt to clip around your waist.
Thats a diddy picture:D
Looks a good idea, just as long as no one trips over the lead and pulls you off your steps when doing R2 on a chanderlier!!
made a lead years ago from long length of single 1mm and a couple of croc clips. Not as pretty but works well enough - disposable and cheap.
So how are these leads then Mark?
Mark,
Just for your ref. I have the KEW version, and I don't use this every day so another would be doubtful, mind it does look useful.
I thought about the cost of materials to make one up, quite small, the time to gather those materials together, quite small, & my time to make this, not very long, however, when I thought about what I could charge that time taken out to customers at, I bought a lead when I was next at the wholesalers!
So IMHO they are worthwhile buying when you consider the package you get against the overall time you spend making one up.
Mark,
Are these leads to be held in WONDERment because they are WONDERful ? Or are we talking WANDER leads , that one WANDERS around with . Sorry :coat :coat:x
Nufing like havin your dikshon pulld up on a forham is ther, promis to tri harder nxt thred. :_| ;)
So what did you think of the WANDER leads?
I feel unable to form any opinion on the leads because the pic is too small to see.
The only other leads I've seen are getting on for a ton apiece. Way too much. Something for about 30 quid would be more like it. Otherwise I'll stick with my 20m of Maplin ultra flexible single.
