daddydisco
- Feb 9, 2009
- 17
- 0
Its the newer version I believe, its one meter with one lcd display. You press a button to cycle between the rates.
You have missed my point. From your pic this could not have happened. Were the 13A plug & sockets you mention already there, are were the old switches/spurs replaced when the old heaters removed ?The convection heaters were removed and their fuses taken out of the main consumer unit so they have no power to them at all, the replacements were provided on 13amp plug in sockets and don't use economy 7 at all.
From that comment i still think my original diagnosis is correct. Someone has linked out the C/U internally. The time control could still be stuck on on, but that would be unusual.Well, I will see what British Gas say when they have checked the meter. I agree with what you are saying Bager but that wouldn't happen from just disconnecting and reconnecting the storage heater would it? If I remove the appropriate fuse from the consumer unit (from the economy 7 side) then it isolates it, so it is definitely connected to the correct part of the consumer unit. So all things point to either a problem with the consumer unit(which hasn't been touched) or the meter.
Thanks for the help Slip+SlapYou have missed my point. From your pic this could not have happened. Were the 13A plug & sockets you mention already there, are were the old switches/spurs replaced when the old heaters removed ?
IMHO that is your problem!I have noticed a problem with the meter. With economy seven you have 2 readings on the meter, the economy seven or the night low cost meter has not moved since around summer time. So I think this may be related. Presumably as the cheaper rate has not been moving then I have been paying full rate for everything for the last 6 months.
Ok, no need for an internal picture then. Looks like i was wrong (again) BlushingThanks for the help Slip+SlapThe heaters were just plugged into spare sockets on the ring main that were already there, not hard wired. The old fuse spurs are still on the wall with nothing connected to them which used to have the storage heaters connected.
The Consumer Unit was untouched, I can take a pic if that would help, not sure the cover has been off in a while.
I haven't changed my supplier for about three years, so it's not that. I am thinking you might be onto something with the rates though, my bill does show both and even their 'actual' read of the two rates but it sounds like there is a mix up somewhere. I got a new meter installed about 1.5 years ago a new fangled digital one, with a cycle display - not sure if the timer is built in or separate. Hopefully British Gas's check off the meter tomorrow might throw up a few answers.You haven't changed electric supplier have you and they have come out and stuck you on bog standard day rate? NOT eco 7 & day rate,Have a look at your last bill.. Is the economy 7 rate listed?
i.e.
If you are on Eco 7, dual meter, normally, although night rate is cheaper.. your Day rate is slightly higher than 'bog standard day rate'!
Whereas if you never had eco 7 dual meter, the rate throughout the day is actually somewhere in between the above two rates.
** note you still get the variable bit of "x" kwhrs at "a" then rest at "b"
so what I am getting at is..
does your bill say you should be getting eco 7?
or have you been put onto standard 24hr day rates.
Its illogical captain!
Thanks for everyone's help, much appreciated definitely as advertised the most helpful and friendly forum on the web!
That is good to hear Daddydisco, both that you have resolved your problem and that the forum is 'as advertised'. All we can do now is wish you well with sorting your bill out. Do come back soon, you do not need to have a problem to be welcome here.Just have to speak to British Gas now about how they are going to sort my bills out, I can see it taking allot of letters and allot of phone calls. :z
Sorry to say they do because I had mine changed by BG and it has the time, and date displayed but does not change the time when BST starts and ends.most newer meters dont have a timer in them - they have a radio controlled siwtch to tell it when to change to off peak/on peak
