the consumer unit and meter used to be under the stairs but I had the meter moved outside as the under stairs is going to be a toilet
the meter is outside and the consuemr unit will be directly behind it inside. I look into moving the CU elsewhere but apparently its not possible because the wiring wold be too long
electrician did mention something about putting another box in to the external fusebox which will allow me to have longer than 3m tails but the outside box is too small to take it.
