I think its plain daft if the CU is mounted at Part M heights, unless its in a cupboard.
just saying!
just saying!
but is the cupboard wheelchair accessable!?I think its plain daft if the CU is mounted at Part M heights, unless its in a cupboard.
just saying!
I'm not against it, I'd rather sit on the floor to work on a CU than stand on some steps! Just saying it isn't a requirementI think its plain daft if the CU is mounted at Part M heights, unless its in a cupboard.
And if it's accessible by someone in a wheelchair then it's also accessible to children.but is the cupboard wheelchair accessable!?
If the door is wide enough!but is the cupboard wheelchair accessable!?
Where is this from?From Part M - 2015
Was this from a random Google result or is it listed on the gov.uk site somewhere? If you follow the planning portal to the correct place you get the 2013 version, which means to me that the 2015 version is not yet in force.
Unless you are disabled then it would be seen the other way around. Calling someone round every time the RCD board trips.I think its plain daft if the CU is mounted at Part M heights, unless its in a cupboard.
just saying!
states in force 1st oct. might not have been updated on planning portal website which is why i didnt see it eitherWas this from a random Google result or is it listed on the gov.uk site somewhere? If you follow the planning portal to the correct place you get the 2013 version, which means to me that the 2015 version is not yet in force.
Yeah, I've just been through it all and no mention of consumer units at all. The wording is completely different, does seem that it is not a minor change between these versions.searching 'consumer' on previous versions comes up with nothing
Only by complete fluke!Where is Andy - Essex is right AGAIN!!!!!
You don't know what fun you are missing out on!and you all failed. I do not even do domestic works. Come on guys!!!!!
Haha - sounds like it....You don't know what fun you are missing out on!
