i was thinking something similar. id imagine if they were at an angle to catch the wind, then in strong winds, it would take a lot of braking force to stop it. dont know what type of braking system it uses (guessing disc or drum?), but if its not large enough would overheat rapidly and lose braking power.One can only speculate what happened here. Did the blades not furl but the brake was applied regardless causing the brake to overheat and catch fire?
makes you wonder how fail safe these things are - obviously each one will need power to apply brakes & work other control systems if its too windy, so whats the plan incase of strong winds & (external) power failure?
