- Nov 30, 2008
- 916
- 51
evening, been asked to fit a wireless stat but never done one. has anyone got any advice.
cheers wayne
cheers wayne
do you take the power from wiring centre or programmer/timer?we use the ravenheat ones .. less than 50 for the full unit.. programmable room stats .. we use 5 core from the reciever to the boiler makes a nicer job.
make sure its heat resitant though
sorry noz just realised you said you use the the salus ones. where do you take the com and no from, time clock do you mean the programmer (sorry not really done anything with central heating).I do a lot of the Salus ones - the RT300RF wireless digital roomstat and the RT500RF wireless digital programmer...These all have the same receiver unit L&N in with a COM/NO/NC switching... they come with a link from L to COM which I have found needs to be removed... if you take the power from the timeclock (which you would if you leave the link in) then when the timeclock turns off and then back on you can get a communication problem.
So I now always wire them with a permanent L&N and take the timeclock output to the COM and then NO to the boiler demand.
They also have jumpers to select 0.5 & 1.0 degree increments (leave at 0.5) and a set of 5 jumpers to code the receiver and transmitter (make sure these are the same random code)
HTH
so leave it connected and just add new conductors to wireless transmitter in same terminals?There is a building reg that states that a roomstat must be fitted -- even if all the rads have TRVs!!
And a pig to check that heating system is working right if there is no stat.There is a building reg that states that a roomstat must be fitted -- even if all the rads have TRVs!!
would you leave the current one connected as well as the new wireless one?And a pig to check that heating system is working right if there is no stat.
Why do they want a wireless one if they already have a wired stat?would you leave the current one connected as well as the new wireless one?
its been put in a really awkward place, moving it would be alot harder than fitting a wireless one. also would to be able to operate from all over houseWhy do they want a wireless one if they already have a wired stat?
