the bottom line is the rules permit you to sign off A.N. Others work, this is something that needs to be gotten of of some peoples mind,someone else does NOT always mean a 3rd party.
Indeed!
With reference to this QS countersigning other person work.. and specifically just in case any members are getting confused, or thinking on cross purposes... lets just explode some of the............
"THE MYTHS OF THE SINGLE SIGNATORY CERTIFICATE":-
Looking at the evidence and considering a few facts to help :-
a) Page 332 BS7671 The standard all purpose all singing and dancing EIC..
also seen on Page 143 of On-Site-Guide.
also know as 'Standard form F2'
This has the following;
2 x Signatory lines for Design
1 x Signatory lines for Construction
1 x Signatory lines for I&T
Then on Page 333, (145 O.S.G.), it has
4 x Company names & address boxes for each of the respetive persons.
So FACT 1: this model certificate quite reasonably assumes that 4 independant persons, for 4 independant companies could be involved in the same installtion work project signing thier respective elements of work.
As far as BS7671 is concerned this certificate could be used for ANY and ALL types of electrical installtion however big or small!
B) Where a single contractor does all of these aspects of work the Short form F1 can be used.
See page 137 On-Site-Guide.
c) Minor works would generally be considerd to be carried out by a single person..
Page 335 BS7671 or Page 150 OSG
This only has one signatory for Design, Construction, I&T.
d) The PIR forms also only have a single signatory..
Page 337 BS7671 or Page 152 OSG.
So thats all clear then....
ONLY the standard form F2 has the multiple signatory boxes when you could possibly have multiple parties involved in the same contract..
OR IS IT???????????????????
What about the Scheme providers own certificates....
Specifically in relation to the Part P compliance aspect...
e) An NICEIC DI standard EIC has ... As Noz also pointed out...
TWO signatory boxes...
1 x Signature of the person doing the Design, Construction, I&T
1 x Signature of the QS verifying that the above persons results have been reviewed as satisfactory.
f) and even an NICEIC DI Minor Works certificate has ...
SO even the NICEIC DI 'EIC' and 'MWC' assume that the posiblity that the person doing the work is NOT the QS who has been appraised as competent by the NICEIC assesment process..
BUT they would be part of the same small enterprise.
So as Steptoe & Noz have pointed out..
Countersigning someone elses work is NOT the same as countersigning 3rd party work.
So back to the original point if the elder spark was working for Scragg
then this other spark even though not assesed as competent by an approved contractor scheme, could do the work, test & sign his bit and scragg countersign and notify the work....
BUT..
if the elderly spark is not working for Scragg then technically he is a 3rd party and scragg cannot sign his work off!
:Salute :coffee
