- Mar 28, 2008
- 14,619
- 1,299
Making up your own rules is IRRELEVANTDoes building control design and construct. No they don't. But what they will do is inspect all wiring at 1st fix stage. Inspect at 2nd fix and look at certificates and then and only then sign it off and issue a building compliance certificate. A QS at a large company would normally be the chief tester, SUPERVISOR or somebody in management. It will not be the general sparky or sparks mate. It WILL be the QS that oversees everything do the final paperwork and notify BC. You can bet your bottom dollar that he would probably not have designed and install/constructed it. I fail to see what the problem is. I will be involved with the project albeit not on site doing the complete install. A larger company would not issue a 3 part EIC would they. But they should and this is one of the issues I was crbvcurbvubruvbruvbfruit to raise. As far as standards go I can assure everyone on this forum I do not certificate anyones work UNLESS I am involved in some part at all stages.
e.g. I could say "I fail to see what the problem is with me speeding"
because...
If Police and Ambulance drivers can drive in excess of 70MPH safely...
And formula 1 drivers can drive at 100+MPH safely
and the Stig can take a reasonably priced car at a speed in excess of the national speed limits..
I don't see you its wrong for me to exceed the STATUTORY legal speed limits....
But then again ALL of the solicitors I have questioned about this tend to think my case it NOT water tight!!!!!
Maybe you could back me up on this one?
then again..
most probably not because.
1/ I am not the Police!
2/ I am not an F1 driver!
3/ i am not the Stig on a test track!
and back to your point
YOU ARE NOT THE LABC!!!!!!!!!!!!!
go back read Approved document P
it is quite clear and easy to follow for all various parties as to their procedures and obligations..
including
a) DIY homeowner
B) Qualified spark not approved to self certify
c) Qualified spark approved to self certify
d) LABC
Just to add
please answer post #77 or are you trying to ignore it?
WHAT DO THE CERTIFICATES YOU SIGN ACTUALLY SAY?
