Another Maths one
skystorm
Jun 27, 2009
53
Scotland
HI all back on nite shift
A 2.5 kw heater is in use for 7.5 hours daily and energy cost 7.1p per unit. the total cost of running the heater over a month of 28 days is =
HI all back on nite shift A 2.5 kw heater is in use for 7.5 hours daily and energy cost 7.1p per unit. the total cost of running the heater over a month of 28 days is =
unless your going to try and answer the question yourself, then im not.
ok
i will help you out cos my learned friends wont
show us the four multiple answers...and ill have a stab without calculations !!!!
Hi -
This whole question hinges on knowing that a unit is 1 kWh.
Once you've got this you can work it all out from basic maths - ie no of kWh = no of kW x no of hours. Total cost is no of kWh x cost per kWh.
This is a basic question - but others can be complicated by putting in non standard units - minutes Watts, Megawatts etc - so you will have to know how to convert to to the required units to get the sum right.
Hope this helps.
