there is a solid core running through. just sleeve and connect this to earth terminalhow easy is it to terminate the earth shield?
looking at the information on it, it says it can be used outdoors, so i dont see a problem using it. could even be used in higher risk areas, after all, anything penetrating it has to pass screen first same as SWASo no stupid glands, brill. Would you consider using this stuff outdoors if in a lowish risk position (say part way up wall) instead of SWA??
