connormcleod
Hi. Recently moved into a new flat and I have this large window, around 7x7ft. Limited space to put curtains. I am planning to install a curtain pole from the places marked red. I have ordered a wall scanner, but no matter what It says I am still going to want to ask you guys if this is a no-no place to drill.
There are no plugs or light switches on the entire side that this window is located. It is a first floor on a block of flats, built around 2010. UK.
If the scanner says it's clear, is it likely going to be ok to drill?
(I'm happy for the curtains to be inset from the window because I intend to put two large plants in the alcove, so I can close the curtains in the evening but then not have to worry about opening them in the morning before I go to work - to ensure my plants get daylight.)
Thanks for your help.
