Consumer Units and Gas Meters
Revved Up Sparky
Aug 3, 2009
752
North Wales
I'm doing PIR's on some houses where the Gas Meter and consumer unit are side by side inside the same cupboard.
I know this could be an issue with external influences etc (eg risk of an arc igniting leaking gas) but cannot remember (at this time at least) if a particular distance is stated in the regs that a gas meter can be from a consumer unit.
Any info greatly appreciated - thanks
It's covered in the front of the OSG. 150mm springs to mind, or less if there's a suitable barrier to compartmentalise the boiler and CU.
