- Dec 22, 2008
- 3,490
- 0
You deserve one just for that post aloneKME!!!!!!
Scooby Snack time M8 me thinks???![]()
R - tis - that!Afternoon Spec.
Dry and Humid, down here Mate.R - tis - that!Keeps raining up here...![]()
but got I jobs in the garden that I need to get done!! :_| :_|
dohX( X(
Perhaps to help a bit..
are you aware that to identify quoted text you can..
a) use to button on the edit window.
B) quote the whole text when reply
c) put the word
so it is only possibly where the earth path is left open circuit?3a 2.This time at 20metres away, in a garage for example cos a mere 5m is a bit close.Lets consider an illustration..
3a] R1+R2 (5m 2.5mm) = 0.09755 ohms (from table 9A pg158 O-S-G.)
Zs = 0.72 + 0.09755 = 0.81755 ohms
PFC at light = 249/0.81755 = 304.6amps (0.3kA)
3b] Potential @ MET with ref to mass of earth;
(PFC x Ze), 304.6 x 0.72 = 219.3v
r1 + r2 x 20 = 0.3902
Zs = 0.3902+0.72=1.1102ohms
pfc=249/1.1102= 224.28 amps
voltage at met=224.28 x 0.72 = 161.48volts maximum
Nowhere near 230volts
The 161.48volts is the figure the fault current will be TRYING to achieve, but the mcb will try to prevent by limiting this to 5 times its rating for type b.
Well yes..so it is only possibly where the earth path is left open circuit?3a 2.This time at 20metres away, in a garage for example cos a mere 5m is a bit close.
The 161.48volts is the figure the fault current will be TRYING to achieve, but the mcb will try to prevent by limiting this to 5 times its rating for type b.![]()
thats bloomin obvious if its a longer run..
I agree with that one
And whats more...
the post was far easier to follow
non of them nasty capitals...![]()
should make debating far more fun all round;\
and whether we...
agree to agree...
agree to disagree...
disagree to disagree...
disagree to agree...
or any other combination (series or parallel?)
I'm sure neither of us want to go givin ZeeSpark another headache!!! :^O
Shall I turn the light out and close the door?
or does anyone else want to use the room?? ]![]()
One more thing before i put me calculator away and try another topic, the 161.48 volts is not the touch voltage. The touch voltage is the voltage from the fault to the met. When the met is at 161volts this means that all other bonded metalwork is also at 161volts to make the faraday cage. The touch voltage in this case will be just the voltage created along the ccts cpc wire, so we must calculate 1.5(from the table) x 20m x 224amps = .o1210x20x224=54volts.so it is only possibly where the earth path is left open circuit?3a 2.This time at 20metres away, in a garage for example cos a mere 5m is a bit close.
So the touch voltage in this case is 54volts
Good night mind the bugs dont bite.
first time to be called everything I suppose.Dave in a tn-s system if the Zs at the garage is too large but volt drop is okay, then simply put in an RCD at say 100mA then a Zs of 500ohms is ok.Right everybody listen, and that includes the supreme being commonly known as steptoe.
can someone clarify this for me please.....so it is only possibly where the earth path is left open circuit?3a 2.This time at 20metres away, in a garage for example cos a mere 5m is a bit close.
since when did an MCB limit the voltage to 5 times its rating,
that would make it over 1Kv for a standard MCB so that is both nonsense and rubbish,
an MCB is a current limiting device, nothing to do with voltage....
I was HOPING someone else would say that.can someone clarify this for me please.....
Thought I was going n*****g futs!
I can clarify that AFAIK, that ranks along with:
COS A HIGH CURRENT FLOWING THROUGH A HIGH RESISTANCE WILL CREATE A HIGH VOLTAGE..SIMPLE ELEMENTARY STUFF
erm........Anyone for a stiff whisky?
just give me the bottle...I was HOPING someone else would say that.
WTF...
your sig makes more sense.....
I think that speaks for itself,,,
talk about big holes and jumping in them,,,,
deffo makes a very good case for enforced euthanasia... ]![]()
