Nicky Tesla
- Apr 30, 2008
- 1,684
- 22
oh!! that cable sheath.........you mean the sheath on a tn-s supply, sorry K
That's better, I can take my ear defenders off now, you have stopped shouting, Nicky.oh!! that cable sheath.........you mean the sheath on a tn-s supply, sorry K
As i mentioned before, it is the fact that it comes from a tnc-s system that is the issue, it also mentions this in that connections mag report mentioned earlier, but this was brushed aside.On my 17th edition course earlier this week the lecturer asked how many of us made garage installations TT when house was TNCS. There were 25 electricians in the room, and a few of them with their own established companies who had quite a lot of sparks working for them. None of them had ever TT 'd a garage and they thought it was a waste of time!
the fact it is a PME/TNCS system has absolutely nothing to do with it.As i mentioned before, it is the fact that it comes from a tnc-s system that is the issue, it also mentions this in that connections mag report mentioned earlier, but this was brushed aside.The problem comes from a possible broken neutral and the problems that creates, nothing to do with all this rubbish above..
I just wish in these reports they would actually explain fully why they show to do things are to be done a certain way and not just because they said so, then it would not create all this confusion.
CORRECT COS A HIGH CURRENT FLOWING THROUGH A HIGH RESISTANCE WILL CREATE A HIGH VOLTAGE..SIMPLE ELEMENTARY STUFF
BUT WAIT A MINUTE YOU SAY IT HAS TO BE 230V MAKE YOUR CONFUSED MIND UP
I like it Dave. Very, very good. I agree (obviously) with TT on the remote install; for reasons I`ve already covered. Statistics? We aren`t concerned with statistical probability generally, as sparx. That statistical analysis doesn`t quite hold up, for the following reason:At 88 posts I'm not sure my re-input is going to help here - but my interpretation is that this is a matter concerning bonding. If there is bonding on the remote installation - then there is a chance of exteraneous voltage on the bonded metalwork meaning a lot of current needs to be taken to the MET. If it is a TNCS system the Ze will be very low - so the current may be in the kA range - so by the adiabatic equation the conductor size should be very large. As there is no fusing involved in this path - it is even questionable whether 5s is enough time for this current to be taken to maintain the 'Faraday cage' effect. So the solution is to TT the remote installation - makes things more managable. Now there is a different debate with boding. It has been said that 40% of houses have no bonding whatsoever. It is assumed that if an exteraneous fault is introduced to an installation the fault will exist for under 5s - otherwise the Adiabatic calculation doesn't make sense. Now considering the number of seconds in a year - the chances of being in contact at the time - the chances of the fault in the first place - the chances of a bonding accident are less that being struck by lightening. No excuse for doing it wrong - but how do you explain the risks to the layman when there is no evidence of the hazards as an accident statistic.
Light blue touch paper - can we get to 100 posts!!!!
Dave
I will start by apologizing for the capital letters, i was not shouting, its just that using capitals makes it easier to see my response when mixed with the quote.If it`s simple, elementary stuff, why`d you get it wrong my friend. If your comment above were true, the National Grid wouldn`t run at 300KV+.B)
If (basic ohms law) V=IR (and I+V/R and R=V/I)
then for a constant voltage, there is an inverse relation between current and resistance. NOT a direct relation.
for example:
lets assume, for ease of calculation again, that we have a fixed voltage source of 100V
Next, we`ll calculate 2 current values; 10A and 100A
10A : R=V/I =100/10 = 10 ohms.
100A : R=V/I =100/100 = 1 ohm.
Special and I are trying, so please don`t shout in your replies.![]()
I`m only taking one small topic per post; as you seem to lose the plot (no offence intended) with the longer posts.
And, oh yes. My calcs weren`t incomplete.
KME
However - the fault described there is a user induced fault - and if there is any form of supplementary bonding in the system then this will not be an issue as the currents will always be (comparatively) small due to the fusing. In my experience supplementary bonding is often present in some of the most unlikely properties either by design or accident with boiler cross bonding, under sink connections, shower installations/water boilers etc - and this will catch the faults described - as indeed would an RCD.The extraneous fault is likely to be intruduced to the circuit by some action on the part of the user (plugging in, switching on, or hammering a nail). If you calculated the probability that they may be in contact with an item of exposed / extraneous metalwork; you`d be looking at a different scenario.
Really sorry bout the headache M8..Lots of info but you buggers have given me a headache now:_|
extract from post #86 Nicky Tesla
That indeed is a very good idea sirKME post #89I`m only taking one small topic per post; as you seem to lose the plot (no offence intended) with the longer posts.
Nicky Post#77option 2) two conductors
so it is only possibly where the earth path is left open circuit?Quote from nicky post #79ALSO 230V CAN ONLY BE PRESENT AT EACH CCTS CPC WHEN A FAULT OCCURS IF THE MET IS DISCONNECTED FROM EARTH AND NO EARTH ROD OR EQUI BOND EXISTS
