unless you are VERY friendly with your neighbour you are not going to be in contact with their earth and yours at the same time as a fault developes and decides to use you a an additional conductor for a parallel path to earth!Hi Steptoe - I'm fairly new and limited to domestic experience to this so bear with me - but I can't see why you are against the mix of earth types - particularly with a TT-TN mix. Considering an exported earth to a garage with water supplied via a metal pipe - you would definitely bond the pipe. How is that electrically different to connecting to an earth rod?
By adding an earth rod at the garage end surely you are giving a belt and braces earthing point for the RCD to act on in the event of a failure of one earth or the other.
My other point is how independant can earthing be anyway? Two terraced houses are not going to have completely independant earths - they will be joined outside of the properties boundaries - so why is a parallell earth path such a bad thing if both paths can handle the full pfc? The ultimate parallel earth path is the earth iself!
Could you elaborate please - it's obviously something you feel deeply about and I want to understand.
Cheers
Dave
you do NOT export the earth!!!Hi Steptoe - I'm fairly new and limited to domestic experience to this so bear with me - Considering an exported earth to a garage with water supplied via a metal pipe - you would definitely bond the pipe. How is that electrically different to connecting to an earth rod?
Well there you go!Your diagram proves yourself wrong. Cos the voltage exported to cct b from the dis board earth bar is not the same voltage that is present at the fault cos the fault current has had to pass through R2a first which creates a voltage at the earth bar lower than at the fault. So it is not like a load of resistors in parallel is it, but in series like i said.
"Furthermore, the voltage will be exported to the exposed conductive parts of circuit
I think that sums up 50+ posts quite nicely Mr Steps!!you do NOT export the earth!!!
I'd second that Dave.SL and Mr Steps,Thanks for your replies - I can now see what the electrical issues are and understand the advice of not mixing earths - paricularly when bonding is involved.
It really is good that people will spend the time to help get others to understand why the regs are as they are rather than mindlessly quoting them (as seems to happen on some other forums!).
Cheers
Dave
thanks Dave,SL and Mr Steps,Thanks for your replies - I can now see what the electrical issues are and understand the advice of not mixing earths - paricularly when bonding is involved.
Cheers
Dave
you really have no concept of earthing have you.?What if an extension is built from the garage to the house then yippee! we can wire it the same as the rest of the house now.---------------------------------------------
I agree with everything that the niceic have written in this thread and it backs up everything that I say and demolishes your theory not mine.
How on earth can a cpc of 0.1ohms have a voltage across it of 230v in an instant which means that there MUST be 2300A flowing through it for that to be true. And Where did all the rest of the 230v go if you say in your last reply that only "maybe a volt or two" would be dropped across the cpc.
The niceic have it right like me, cos the voltage may RISE to a touch voltage of 50V at the earth bar and be EXPORTED to other cpcs at that potential. according to you all your ccts could have touch voltages of 230v in a fault condition.
I don't meen to be rude, but are you actually reading anything i write, or are you just brushing it aside.
I like to learn from constructive criticism
dude i think ur digits are on some sort of roids cos dayumn u can lay some letters down cant yaHey Biker Mike.....due reckon that last post was worth about 10 posts.?^O:^O:^O
