hi,
i'm trying to install sockets and spurs in my kitchen and was wondering whats the best way to go about it.
the main input into the kitchen has 2 x 4mm LN cables and 2 x 2'5mm LN cables coming in through the same conduit. plus 1 earth.
these were attached to a cooker switch (4mm). and a single socket spur(2.5mm).
the 4mm cable goes to a 30amp fuse called "cooker" at the fuse bord and the 2.5mm is part of the main "ring main" circuit, also 30 amp.
there is a separate circuit on the opposite wall called "kitchen twin" at the fuse board. this is on a 15 amp fuse.
what i need are 2 double sockets on the main wall (where the main wires come in) and a further twin socket further round on an adjacent wall.
i also need to feed a built in cooker which requires a 13amp fused spur or plug. an overhead fan, and the ignition on a gas hob.
futher round on from the "kitchen twin" socket i would like to install a washing machine socket/spur.
i hope the above photo links work and help explain things a bit better.
the main question is how would you tackle this job re; connecting it all up ??
thanks
phil
thanks
phil
