Sharpend
"It Just Is"
If you have purchased the flat, how/why are the council still involved? Or is it a shared purchase/rent scheme you have purchased with?
forget it. just go ahead and do the job regardless. your going to anyway.no i dont know the max z's of circuit and do not have equipment to test
i'm not entirely sure what safe zones are, can you tell me ?
What do you mean "other methods" of protection ?
Can you tell me how to calculate cable size ?
I will get any work i do tested and certified, which the council will porobably insist on if they are paying for it. But i'll do that for my own peace of mind anyway.
1. Electrical inspectionExamine and test the condition of the existing electrical installation complete. Provide the Council
Phil, don't get me wrong but this work (as stated by others) is so far above your competence level that you shouldn't be doing it.all this just for asking a perfectly straightforward question. where have i given the impression i can't be helped.
some of you guys give a strong impression you're just queueing up to have a pop at anyone who gives even a slight hint that they, as some of you keep putting it, "don't know what they're doing" it begs the question why would anyone ask for advice if they knoew 100% what needed doing.
part of the reason i want to save a bit of cash is that strictly speaking its not so much a grant as a loan. in that you have to pay it back if you ever sell the property. and as has been said, the council will only stand for surface mounted. hence my chasing in preoccupation.
Quite common in older installationscan anyone tell me what the following means and how serious it is. and whether a new consumer unit, ie the wylex skeleton unit suggested earlier, will remedy this;
"TAILS ARE UNDERSIZED FOR OVERCURRENT PROTECTIVE DEVICE"
thanks.
Contradiction in terms surely, Competent at what? flat pack furniture, decorating, gardening. Quite clearly from the thread content no competence at designing, installing and testing safe electrical circuits. I have to say that I am inclined to agree with Betty's summation of the problem in his last two posts. (#59 & #56) Stop beating about the bush and get three independent quotes for the work you want doing, then do it properly and you will save cash because you will not be spending more money in 18months - 2years, to put right all of the bits you got wrong and you will save on the LABC notification & compliance testing costs.i'm a "competant" enough diy'er but i've never tackled this extent of electrical work before. so really i'm not sure what connection boxes to use to start the circuit off.
