Hayden Yale
- Joined
- Feb 10, 2012
- Messages
- 2
- Reaction score
- 0
Hi guys,
I recently moved into an 8 year old house and found that all of the light fittings upstairs have different fittings than the standard bayonet fittings that I'm used to (and that are used downstairs).
I read up on this and it looks like 25% of fittings in new homes need to be forced to be energy efficient thanks to changes in building regulations.
Yay!
The problem is that all of the lamp shades that have been moved from my old house don't fit the new fittings and the new light bulbs are very expensive when compared to the cost of standard energy savers.
Therefore I'd really like to change the upstairs fittings to standard bayonets if possible.
The current fittings are 4-pin and you simply click the light bulb in and out. The light bulbs say on them "Osram Dulux T/E 13W / 827".
The actual fitting is a strange box that looks like it is screwed onto the hanging light cord.
Is it possible to make an easy switch? I'm not great at DIY so would appreciate advice.
If i hire an electrician to do the job, would it be really easy for them (and therefore cheap)?
Thanks,
Hayden
Yay!
Thanks,
Hayden
