Low watt led bulbs
DIY GUY
Sep 17, 2017
274
5
Can anyone recommend good quality exterior led gu10 bulbs to work outside? Have got 2 fitted atm, only been fitted for 6months and both have went very dim on separate occasions. I’ve replaced the first bulb with the exact same type when it went dim, second one has now went dim and don’t want to waste my time replacing that one with the same brand as will probably happen again.
Just try brand names for led bulbs that you recognise.
don’t buy cheap
also when you say external, type of light fittings do you have ?
It’s like this style, I got 2 bulbs with the lights. I’ve had a look online for new ones but most say for indoor only. If you don’t mind could you give me a link for ones that you would recommend. Don’t need them to be dimmable
    1.3 MB
