ecasam
Hello All. Hope you all had a great Christmas.
My friend called me round for the following problem at his house. He could not reset his MCB to the downstairs sockets. After investigation I found a short in the first leg of his ring main supplying 12 sockets. As he was lucky (in a way) that it was in the first (or last) feed from the CU. I changed the 32amp MCB for a 20amp and made it a radial. All readings were OK. I put it on a 20amp MCB, but is that OK or should I have got him an rcbo, as his board has no RCD protection.
Thanks in advance for replies.
I wish you all and myself good luck for 2009.
