Texdangerfield
- Aug 11, 2011
- 10
- 0
My dear and beloved mother in law informed me of her intention to buy a 3 phase ice cream machine for her food kiosk. She owns a patch of land and has a food kiosk on it. Naturally she thinks electricity is stuff of wizards and witches and it all just works with harry potter spells.
When inspecting her land and power supply I found that she has a 3 phase supply. Two of the phases each feed old unused consumer units that fed various commando sockets for old leisure equipment. Her third phase feeds the kiosk, which consists of two piggy backed 16mm 3 core armours that run along the land and are fed directly into the kiosk and into an old consumer unit with a 30ma rcd. The run itself is an estimated 30 metres.
Obviously the problem is the kiosk has no 3 phase points, further inspecting the land I found both piggy backed armours are dangerously jointed half way through the run and have an IP protection of plastic box and sandbags. Did I also mention this ground is prone to flooding?
I'm proposing ripping it all out and running a new 3 phase armour to the kiosk. But what options can I use in regards to mobile equipment and not directly feeding an armour into the kiosk? I've not much experience with kiosk/caravan installation but is a sort of system that could be arranged to allow me to upgrade the consumer unit to 3 phase while maintaining some type of socket-like connectivity to the kiosk?
Or is the option of simply running a direct 3 phase cable with isolator directly into the kiosk to feed the machine acceptable? I'd much rather have a single supply feeding the kiosk entirely. The kiosk from estimate has all the usual equipment you'd expect such as friars, fridges and candy floss machines.
Thank you. Look forward to replies!
