Cirrus
Distinguished Member
Working on an immersion cct today. Plumber been in loft for 2 days doing all pipework. Just bending over the Neutral on the supply and ....Zing - a belt. Thought I was going mad then 5 mins later I got a belt off the pipework I was leaning against. Made me jump out of the airing cupboard. Then, plumb says that he just got a belt off a pipe in the bathroom. Spoke to occupier and she says that whenever she turns on the outside tap she also gets a belt. WTF!!!??? Put meter across conductors on immersion feed to find 7 volts L-E but 80 Volts N-E but no RCD tripping! Turned off each cct on the C/U and the voltage dropped to 65 Volts at the lowest.
Oil fired boiler has 10mm main Eq bond, as does water. This is a TT system with a 10mm main earth. Confused! headbang
