Outside canopy light
Geoff Williams
Mar 12, 2023
2
Manchester
Hi,need help.im trying to change my outside canopy light which is switched to a pir led but still want it to work with the switch.2 lots of wires from canopy are 1=2 live & earth.2=1 live 1 neutral 1 earth.new light fitting has 1 live & neutral. Any advice would be appreciated.
If I've understood your text correctly you have a permanent live, a switched live, a neutral and an earth (?).
Your new light is not designed to do what you want.
You need one where the switched live is accessible as well as permanent live.
Ok,thanks a lot,need to purchase a new fitting,cheersđź‘Ť
