- Mar 28, 2008
- 14,487
- 1,155
Within a domestic environment using the incoming supply tails where they terminate onto the main switch is considered an acceptable method of proving your voltage tester is still working... well it is by one of the main Part P scheme providers !If you are at the point of isolation there's bound to be something live going to the means of isolation! In a domestic setting, as I suggested above, turn off main switch on CU the incoming tails are live.If in a factory it's a single isolator for a motor there will be a live going in and a dead cable coming out. Other than in the even of total power loss would this not be the case, and then care must be used as installation could become live whilst you work on it!
and they have been happy with this method during my assessments.B-)
Obviously as has been pointed out..
within a commercial / industrial situation..
it may be much harder to have a local "know live source"..
which is where a proving unit is a more useful item.
