- Oct 22, 2010
- 14,533
- 1,105
I will also be needing the 22 way board we talked about....just got to work out what breakers I need
Just.....got in from work
I sometimes have to do stupid hours........set off at 0430" in the morning and come home at 1900 or later!I thought it was only me that worked late.
I like the look of that.Here is a photo of the 22 way DB above, including 2 x MCBs on the same DIN rail as Compacts.
Get your hands off it!Here is a photo of the 22 way DB above, including 2 x MCBs on the same DIN rail as Compacts.
Update
I have been doing a bit of engineering to the ENC-24S 2-tier busbar assembly and I can now make each busbar in one piece, rather than using wires and terminal connectors. The photos show the prototype, which is not absolutely correct, with the vertical section being slightly too long, which has imparted a slight curve to the bottom busbar. The final design will be spot on.
The bad news is that that I had been selling the ENC-24S at less than cost, which can't continue. My new price, including Main Switch, will be £30.00 + VAT. On top of that will be the Compacts and the busbar kit, but it can be configured in any number of ways.
I already have a lot of interest in it, so hopefully I will be able to post photos of actual installs.
SBS Dave
