tom1
Distinguished Member
- Aug 7, 2009
- 2,330
- 0
yer my screwdriver, headbangNo it was Dave in the Utility with a screwdriveropcorn
depending on the angle i'm looking in the mirror will make no difference to who i see by the distance :xMove further away from that mirror, then mate
Get your on site guide turn to page 159 Appendix 8.2.4 if you dont believe me. It says "In an A1 ring final circuit and an A2 radial circuit a non fused spur should feed only one single or one twin or multiple socket outlet" is that myth?? Its in black ans white.
So is the consensus of opinion that I CAN fit two single 13A sockets as a spur on spur and note it as a deviation, because reg120.3 overrides the reg that says I can't, because in this case it will be no less safe.reg 120.3the resulting degree of safety of the installation shall be not less than that obtained by compliance with the reg.
Works for me daveSo is the consensus of opinion that I CAN fit two single 13A sockets as a spur on spur and note it as a deviation, because reg120.3 overrides the reg that says I can't, because in this case it will be no less safe.
Until the customer pops a couple of these on because they need more outlets.So is the consensus of opinion that I CAN fit two single 13A sockets as a spur on spur and note it as a deviation, because reg120.3 overrides the reg that says I can't, because in this case it will be no less safe.
That's a matter of opinion, surely?because in this case it will be no less safe.
Yes I suggested that right at the start, but it's still a spur on spur. I guess two FCU's would mean subsequent changes for a double socket would still be safe.Dave, how does this soundo what I suggested earlier and swap your double socket outlet for a 13A FCU and a single socket.
This then gives you - ring to FCU to SSO (13 A)
Then....
Spur off the supply side of the FCU and run this cable to a second 13 A FCU which then feeds your second socket outlet.
Both sockets are then rated 13 A for each appliance.
Both sockets are limited to 13A by the individual FCUs.
The cable is limited to 26A by the FCUs - even if someone spurs off the socket outlets at a later date.
Happy days
The problem is, Dave, that as the regs stand, anyone can reasonably expect to be able to change any single socket outlet to a double socket outlet without causing danger - even a DIYer.Yes it's one big grey area.We have a reg saying it can't be done.
We have another reg saying you can deviate from regs providing what you do is no less safe, which IMO would be the case here.
Some people raise concerns about "what if someone changes it" well surely whoever changes it should determine that it IS a ring final before altering it and whoever does such alterations is at fault.
Yes, but it's a fused spur, that's the differenceYes I suggested that right at the start, but it's still a spur on spur. I guess two FCU's would mean subsequent changes for a double socket would still be safe.
I believe the purpose of that Regulation is more for new innovations since the publication of the Regulations.We have another reg saying you can deviate from regs providing what you do is no less safe
Not really. Its still 2 accessories and by your design you are planning on drawing 26A down that spur cable that can take as little as 20A and still comply.Yes, but it's a fused spur, that's the difference
Well that's about how it has ended up.Am I missing something here. You say, you dont want/shouldn't be doing spur on spur. Which is reasonable and right. The existing socket is a double and the appliance lead will not reach for 2nd appliance. So, why not just run an extension behind the units as you would have done with the twin. Plug into dsso and screw the socket end to the wall. Explain everything to the punter first explaining the regs as reguards spur on spur, etc. Job done. regs abided by and punter gets somewhere to plug dryer in without trailing wires all over.
