Here is my main unit the 2nd RCD on the right is the bar one inside but the whole thing trips from the RCCB to the right side.A photo of the main house CU would be useful
Yes it is. just unplugged everything and everything stayed on for 10 mins then tripped out the RCCB in the house??.Is the 2nd CU supplied by the unlabeled B32 MCB?
Looking at the distribution arrangement I would have to ask an installer qualified in what, I doubt the proper application process has been carried out for the extra connected load of an EV and looking at the size of the sub main to the bar I doubt any calculations have been done to verify it has the capacity to feed an EV chargepoint as well as the bar which I would assume is heated using electric heaters so it is likely that it is overloaded at timesOnly a EV charging point by a qualified installer last August which is on a separate RCD.
100% and were on it thanks. Just very strange that this starts now after 4 years. I really think its something between each socket in the walls.Qualified electrician required. Your son should be able to contact one.
Found the issue between 2 double sockets. The electrician thinks running on 2 16amp RCBO and splitting the load?.
