- Oct 22, 2010
- 14,525
- 1,095
Come to think of it.....you are correct!Canoeboy said:At 400sq.mm its more than likely bi-rated :Salute
and the BCF fire supresant system
Would it not be easier to fit some fusetape leading from inside the CU to a pack of whistling rockets beside it,?
Surely when the fire starts and lights the fuse the noise of the rockets going off and banging around under the stairs would alert you,?!?!?! :|
Is this an after drink thought? Blinding idea all the same!Would it not be easier to fit some fusetape leading from inside the CU to a pack of whistling rockets beside it,?
Good question. I found this thread http://www.theiet.org/forums/forum/textthread.cfm?catid=205&threadid=62760 which goes into detail about it.Why does the TD RCD need to be in a external plastic CU?
I want to scoob that for comedic value, but that isn't really appropriate!
