Sugar in the fuel tank, what enemies you got !!
yes, think it is.If the fuel has dumped into the cylinders, then it could have hydraulic locked, which is like a seizure, but is simply the incompressibility of the fuel above the piston, this will seep away naturally as a static piston is not a perfect seal in the bore.
It could simply be a single injector failed open dumping the fuel into a single cylinder hence the amount of fuel lost?
Is it a common rail engine?
