I needed some valve clearances for the '30
and got some spare smoke to keep in stock,
I have yet to see one that isnt down to bad install,Canoe, I get the distinct impression you have a real downer on the PV industry, there are quite a few systems out there and they are not all bad, the voltage tripping problem is not just down to 'muppets' as you put it
I think you've come to the wrong place thenlike it Steptoe, we prefer selling through education not vapourware or as you put it bottled space
Give me time and maybe just maybe I can get you guys to see the light
ok so how come any VO unit I have seen, and I've checked quite a few, say to feed the PV into the meter tails BEFORE the VO. I have my own PV system, send me a VO unit and I'll fit it and report back...Sounds like my sort of place and apparently Steptoes
If the grid voltage was 240v then the inverter would see 225v, it would then say export at 227v which would be stepped up back through the transformer to 242v maintain its 2v increase, if the current was utilised in the property then it would circulate through the transformer and again reduce by 15v giving the house a beneficial 227v generated or/and 225v from grid.
This all sound very cosy apart from you cannot do it to comply with G83-2 if the upper voltage thresh hold is set at 262.2v at the inverter. Make sense ?
If the inverter were set at 253v then we could stop it tripping out as it would see a reduction in voltage and in essence kid it but stay within the 262.2v range under G83-2
Inverters rarely trip out due to grid voltages, I've had one in 3 years doing this, earth leakage from poor installation is the main culprit, and the DNO are pretty good at monitoring their networks. Having the inverter trip out is actually quite useful, as it flags to the customer that the grid has a local issue that needs reporting to the DNO before their other electrical equipment gets trashed.Hi Binky, it all depends on the inverter setting, if its a G83 install but is set at 253v then we can protect the inverter from tripping out (hence protection) unless the grid gets up to 262.2v where we will automatically stop the export in line with G83-2
