Hi guys, just looking for some advice if possible, hopefully without too much grief as I know I'm not a spark! Just trying.to do my.best to help my Mrs keep the costs down with her new business venture.
I have some limited basic knowledge of electrics and have moved sockets etc. In the house and other all very basic jobs.
So she has taken over a small beauty salon, which will predominantly be getting used for make up, massage, nails etc, however she would like to be able to offer limited hair services also. Iv informed her to do this she would need to have a small electric water heater installed in the premises, as there is no gas supply to the property. To be clear this won't be a hairdressers and constantly using hot water, I know that in order to do that you're looking at high power output showers etc, we're talking most days this unit probably not even being used at all, and when it is, only for 3 or 4 minutes for a quick rinse, so I suggested a small heater less than 3 kW. Could you please advise if so long as its a 2 kW or 2.5kw max that it would be OK to connect this to the ring circuit via a double pole isolated switch, as the premises is in a small unit which is part of a larger premises and a distance from the main room housing the consumer units. If I'm completely wrong with this please just let me know this is why I'm here to try and lean on a bit of experience cheers again
