would this work
stringy
Oct 19, 2008
148
right chaps need a bit of help
went to look at a job today, the woman has a outside 500w pir flood light on a switch inside.....the fitting has a dusk till dawn sensor on so obviously if this switch is on in the day the fitting wont work
anyway she has bought a new fitting for outside which also has a pir on, the house has just been decorated and she wants no damage or trunking inside.
my plan was to chop the cable going into the flood in a place thats not very visable, put into ip rated jb, then out of that jb 2 cables one to new fitting one to flood.
now because both cables are coming out of the jb if one light come on would the other one as well? even though there on seperate pir's?
thanks chaps :p
cheggers
Mar 24, 2008
198
you would have to link the two floods with 3 core for that to work
steptoe
Feb 13, 2008
24,337
117
Gtr Manchester
agree with cheggers.
if you want them to switch together on either PIR then an extra sw wire between the load side of each fitting is required.
if you just simply want them as stand alone then simply J B is fine.
stringy
Oct 19, 2008
148
thanks for the reply guys
i dont want them to come on together, seperate all the way
thanks
cheggers
Mar 24, 2008
198
check your loadings you have 1kw on just the two floods what else is on the circuit .
stringy
Oct 19, 2008
148
cheggers
one fitting is a 500w flood the other is a 60w bc lantern with pir.
circuit is fine only a couple of pendants and the 500w flood
thanks
Mar 28, 2008
13,619
296
just a side point...
most existing 500w floods I work on I replace bulb with a 300w!
in reality not a fat lot of difference 'lighting-wise'.... :p
just saves 2/5ths of the power & electrwikery consumption! :) ;)
stringy
Oct 19, 2008
148
i have started to use the low energy replacements, bit more expensive still give a decent light out but just doin my bit :)
Feb 27, 2008
11,034
just a side point...most existing 500w floods I work on I replace bulb with a 300w!
I do to also saves fittings burning out.
Batty
